Codigo de caixa
fan
Codigo de caixa
Post by fan »
Bom dia
Tenho uma caixa, swing axle, com o codigo BV, mas nao encontro esse codigo nas tabelas, alguem tem alguma informacao sobre este tipo de caixas?
f.a.n.
Qual é o codigo?
fan
Post by fan »
boas
BV 08 01 6
pelo que o jean me informou e uma caixa de brasilia 8x33.
obrigado
F.A.N.
De facto deve de ser brasileira pois não consta nos codigos alemães. Tive uma semelhante no meu carro.
As unicas caixas que eu encontrei em B (BC, BE, BF, BG, BH, BJ, BK) são todos caixas semi automaticas. Sera que BV é uma igualmente?
O Vlad tem uma brasileira de Brasilia que eu lhe ofereci, era interessante checar isso!
N.Moinho
Post by N.Moinho »
E asim pelo que sei
AA 1200-4.375 from chassi n: 0981810
AB 1300 4.375 up to 8/70
AC 1500 4.125 alsa same 1300 from 8/70
AD 1200 4.375 limited split differential
AE 1300 4.375 limited split differential
AF 1500 4.125 limited split diff up to 8/70 also some 1300 from 8/70
AG 1200 4.375 type 147 (fridolin)
AH 1500 4.125 IRS suspensionfrom 8/68
AH 1600 4.125 8/69 8/72
AK 1500 3.875 type 181 trekker up 8/70
AK 1600 3.875 type 181 trekker up 8/70
AL 1500 3.875 type 181with LSD up to 8/70
AL 1600 3.875 typ 181 with LSD from 8/ 70
AM 1300 4.375 sallon and cabriolet from 8/70
AN 1600 3.875 KG with IRS from 8/70
AO 1600 3.875 KG from 8/70
AP 1300 4.375 limited split differential from 8/70
AQ 1600 4.125 limited split differential 8/70 8/72
AR 1600 3.875 KG with LSD from 8/70
AS 1600 3.875 type 1 from 8/72
AT 1600 3.875 1303s and cabriolet from 8/72
AU 1600 3.875 Ditto witt LSD
BA 1300 / 1500 4.375 semi automatic from 8/68 -8/70
BC 1300/1500 4.375 ditto with LSD
BE 1600 4.125 semi automatic from 8/70 8/71
BF 1600 4.125 ditto with LSD
BG 1300 4.125 KG semi automatic from 8/70
BH 1300 4.125 ditto with LSD
BJ 1300 4.375 semi automatic from 8/70
BK 1300 4.375 ditto with LSD
DA 1500/1600 4.125 type3 swingaxie up to 8/68
DB 1500/1600 4.125 ditto with LSD
DC 1500/1600 4.125 type3 with IRS from 8/68
DD 1500/1600 4.125 ditto with LSD
BV 1600 4.125 brasilia
BJ...........VW 1300 e 1300L (até o chassi BJ 284.032 era utilizado
o prefixo BF
BD.........VW 1600
BA..........Brasília carburação única
BN..........Brasília carburação dupla
BV..........Variant I e Variant II
BL...........SP II
BZ...........Kombi
Espero ter sido util nesta informaçao
Corrijam-me se alguma coisa estiver mal mas estes sao os dados que tenho
matos
Post by matos »
Viva Nuno, boa e completa informação.
Cumpts
Matos
Nunca sejas muito normal
N.Moinho
Post by N.Moinho »
QUAL sera a referencia desta caixa as letras sao OO e os numeros o3276 e e dum modelo brasileiro de 1982 sera que alguem me sabe dizer algo !!!!!!!!!!!!
N.Moinho
Post by N.Moinho »
Ninguem me sabe dizer nada sobre esta referencia
fan
Re: Codigo de caixa
Post by fan »
Alguem me consegue ajudar com este codigo de caixa?
É o codigo da caixa que esta no 1300 de 67
F:A:N:
Re: Codigo de caixa
Essa caixa é uma 8x33 com a 4ª 0,89, quer dizer que é uma boa caixa!
fan
Re: Codigo de caixa
Post by fan »
Viva,
Obrigado Rolando, mas como do numero se chega a esses dados? ha alguma tabela?
F:A:N:
Re: Codigo de caixa
Sim, existe uma tabela de caixas de velocidades. Uma ocasião eu meti aqui uma tabela de caixas com todas as relações, mas já procurei e não encontrei nada aqui. se procurares em foruns brasileiros, eles tem lá de todas as caixas do modelo brasileiro. a tabela que eu meti aqui era dos carros aleães
fan
Re: Codigo de caixa
Post by fan »
Rolando, a tabela que colocou uma vez era com base nas letras da caixa, mas esta nao tem letras... so numero (não é a caixa BV que perguntava no inicio do topico, mas sim a caixa que esta no 1300 de 67 (fotografica)) e ate agora não encontrei nenhuma tabela para estas caixas??
F:A:N:
