Main Group 1:
Engine
01 - Engine, complete / Engine, short MOTOR, COMPETO / MOTOR, "CURTO"
02 - Crankcase, Mounting Parts for Engine & Transmission CARTERS, PARTES PARA MONTAR MOTOR E CAIXA & TRANSMICÃO
03 - Cylinder, Cylinder Head CILINDRO, CABEÇAS
04 - Crankshaft, Connecting Rod, Bearings CAMBOTA, BIELA, BRONZES
05 - Piston, Piston Ring PISTÃO, SEGMENTOS
06 - Camshaft, Valves ARVORE DE CAMES, VÁVULAS
07 - Oil Pump, Dual Oil Pump, Oil Strainer BOMBA DE OLEO, BOMBA DE OLEO DUPLA, FILTRO
08 - Oil Filler Pipe, Oil Dipstick
09 - Oil Cooler
10 - Housing- Fan, Fan
11 - Cooling Air Controlls
12 - Engine Cover Plates
13 - Fuel Pump
14 - Fuel Line
16 - Carburetor, Carburetor Body, upper part
17-20 - Caburetor Body, lower part
18 - Air Cleaner
19 - Air Cleaner with Connecting Parts
19-10 - Air Cleaner with Connecting Parts, L-Jetronic
20 - Intake Manifold
21 - Exhaust Emission Control System
21-10 Exhaust Recirculation for L-Jetronic
21-20 Deceleration Boost, Exhaust Recirculation for L-Jetronic
21-30 Intake System, Altitude Correction Parts for L-Jetronic
21-40 Fuel Line for L-Jetronic
21-50 Electronic Control Unit, Fuel Pump, Series Resistance for L-Jetronic
22 - Clutch
23 - Release Bearing, Operating Shaft, Clutch Operating Lever
25 - Servo for Automatic StickShift
Main Group 2:
Fuel Tank and Pipes, Exhaust System, Heater
25-10 Fuel Tank, Fuel Filler Neck
25-20 Activated Carbon Container
26 - Exhaust System
26-10 Exhaust System, Catalyst, Fuel Injection Engine (incl. StickShift)
27 - Heater
27-10 Heater (incl. StickShift)
28 - Warm Air Vent
29-10 Stationary Heater, Heater Channel (Type Eberspaecher)
29-20 Stationary Heater (Type Eberspaecher)
29-30 Stationary Heater, Heater Channel (Type Eberspaecher)
29-40 Stationary Heater (Type Eberspaecher)
Main Group 3:
Transmission
30 - Transmission Case
31 - Transmission Case for Automatic StickShift
32 - Transmission Securing Parts
33 - Gears and Shafts
34 - Gears and Shafts, Converter (StickShift)
Main Group 4:
Front Axle, Steering
35 - Track Control Arm, Brake Drum, Brake Disc
36 - Suspension, Shock Absorber
37 - Steering Gear, Drive Shaft
38 - Steering Gear, Drive Shaft
39 - Tie Rod, Steering Idler Arm, Steering Damper
Main Group 5:
Rear Axle
40 - Double Joint Axle
41 - Suspension Shock Absorber
42 - Differential
43 - Limited Slip Differential
Main Group 6:
Road Wheels, Brakes
44 - Wheel Discs and Wheel Caps
45 - Front: Back Plate Brake Shoe with Lining
46 - Rear: Back Plate Brake Shoe with Lining
47 - Brake Master Cylinder
48 - Wheel Brake Cylinder
49 - Reservoir Wiring Brake Master Cylinder
50 - Front: Brake Line, Brake Hose
51 - Rear: Brake Line, Brake Hose
52 - Disc Brakes
Main Group 7:
Hand Lever System, Pedal Cluster
53 - Frame, Frame Head, Floor Plates
54 - Front: Bumper
54-10 - Front: Bumper, Buffer
55 - Rear: Bumper
55-10 - Rear: Bumper, Buffer
56 - Shift Mechanism
57 - Hand Brake Lever
58 - Heater and Fresh Air Flap Cables
59 - Shift Mechanism for "AUTOMATIC StickShift"
60 - Brake and Clutch Pedals Cluster
61 - Accelerator Pedal, Accellerator Cable, Clutch Cable
62 - Brake Pedal for "AUTOMATIC StickShift"
Main Group 8:
Body
63-10 - Repair Plates
63-15 - Repair Plates
63-20 - Repair Plates
64 - Side Member, Cross Member
65 - Body Front Section
66 - Side Panel
67 - Flap for Fuel Filler
68 - Boot Floor Plate, Rear Apron
69 - Roof
70 - Heater and Ventilation Outlets
71 - Fresh Air Controls
72 - Heater and Ventilation Outlets
72-10 - Heater and Fresh Air Flap Cables, Fresh Air Controls
73 - Fender, Sill Panel Trim, Mud Flap
74 - Flap, Front
75 - Flap, Rear
76 - Doors, Door Hinge, Door Seal
77 - Door Lock Operating Lever
78 - Outer Door Handle, Check Rod - Door
79 - Vent Wing Frame, Channel, Window Slot Seal
80 - Window Lifter, Lift Channel, Window Crank
81 - Complete Vent Wing
82 - Window Glasses, Seals, Hinged Window
83 - Side Window
84 - Moldings, Inscriptions
85 - Dash Cover, Glove Box
86 - Grille, Ashtray
87 - Rear View Mirror, Sun Vizors, Grab Handle, Strap
88-10 - Seat Belts, Retainer for First Aid Kit
88-20 - Seat Belts
89 - Lining - Front Panel, Side Member Trim, Luggage Boot Trim (Front), Hand Brake Lever
90 - Luggage Boot Trim (Rear)
91 - Foot Support, Floor Covering, Sound Absorber
92 - Door Trim Panels, Side Trim Panels, Armrest
93 - Trim for Roof and Pillars
94 - Cover - Top
95 - Top Header, Convertible Top Lock
96 - Convertible Top Frame
96-10 - Convertible Top Frame
97 - Steel Sliding Roof
98 - Steel Sliding Roof Parts
99 - Seat (Front)
99-10 - Seat (Front)
100 - Backrest (Front)
100-10 - Backrest (Front)
101 - Seat and Backrest (Rear)
102 - Mounting Parts for Body to Chassis
Main Group 9:
Electrical Equipment
103 - Dynamo Single Parts
103-10 - Alternator
104 - Distributor
105 - Ignition Coil, Ignition Lead, Sprak Plug
106 - Steering Lock, Ignition Starter Switch
107 - Starter and Single Parts, Battery Mounting, Cutoff Relay
108 - Fuel Gauge, Sender, Oil Pressure Switch, Warning Light for Dual Circuit Brake, Cigarette Lighter
109 - Switch ("AUTOMATIC")
110 - Fuse-Box, Cable Connector
111 - Headlamp
111-10 - Headlamp
111-20 - Halogen Fog Lamp
112 - Switch for Lighting Relay
113 - Licence Plate Light
114-10 - Brake, Turn Signal and Taillights
114-20 - Rear Fog Light, Switch - Brake Light, Terminal Pin Housing, Protective Cap
115 - Interior Light, Door Contact Switch, Handbrake Warning Light, Turn Signal
116 - Horn, Buzzer, Horn Ring
117 - Turn Signal
117-10 - Relay Turn Signal / Emergency Light, Emergency Light Switch
118 - Switch for Turn Signals, High and Low Beams, Headlamp Flasher and Parking Light
119 - Windshield Wiper
120 - Windscreen Washer Unit
120-10 - Headlight Washer System
121 - Windshield Wiper
122 - Speedometer, Fuel Gauge, Drive Cable-Speedometer, Catalyst and Speed Control
123 - Wiring Looms
128 - Electrical Parts for Heated Rear Window Glass
129 - Electrical Parts for Seat Belt Warning System
Main Group 0:
Accessories
130 - Jack, Tools, Stickers, Trim Strip
